Voor een dresser en dat is het, is het een keurige maat. Zeker niet te klein!
Sólás Starlight with Aventurine dial
Aventurine is a material created in a kiln – that glistens with understated and subtle pinpoints of light. Also used on a limited-edition Omega Speedmaster. Each aventurine dial is unique due to the way the material is made no two dials will be completely the same.
• Case diameter: 38mm, Height: 9.7mm, Water resistance: 50 meters
• Sapphire with inside anti-reflective coating front and back
• Micro-rotor movement Hangzhou 5000A: 28800bph, ≥42hrs power reserve and blued screws
• Lugs: 20mm, Lug to lug length: 44mm
• Strap: salmon skin upper with full grain Italian calf leather backing
