T ~ 500 m
Antimagnetic
Stainless Steel Case
Automatic, ETA-Movement cal. 2892A2
Screwed Acrylic Glass, 5 mm
Screw-in Crown, 9 mm
Screwed Case Back
Screwed Band Attachments
Case: 42 mm x 57 mm x 18 mm
Screwed Stainless Steel Strap
Leather Strap
The T~500m model has been developed from the elaborately crafted case of the first G&W 500m.
Its special feature is a revolving bezel ring with 5-minute divisions which is fastened with an additional crown at the “4”.
The bezel ring can be turned both ways and locked in any position. The secure fitting means the bezel ring cannot be moved unintentionally.
The bezel ring is attached to the bezel by a ring nut and is impossible to lose. This special attachment and secure fitting only work thanks to the G&W’s unique case design.
The T-500m is, like all G&W models, extremely waterproof and highly anti-magnetic.
