Die zou de pinguïn
This item will be released on Dec, 2024.
SEIKO x BANDAI YUTO
(MASKED RIDER)
Made in Japan
Case: Stainless steel
Dial: white
Diameter: 50.4mm
Movement: Quartz
Accuracy: +/-15 sec/month
€379.43
This item will be released on Dec 6, 2024.
SBSA289
SEIKO 5 SPORTS WATCH SKX SERIES ‘DOUBLE HURRICANE’
Japan only model
Made in Japan
Limited edition of 550 pieces
3 Years International Warranty
Caliber No.: 4R36
Movement Type: Automatic with manual winding
Power reserve: Approx. 41 hours
Jewels: 24
Stop second hand function
Day/Date display
Case Material: Stainless steel
Case Size: Thickness:13.4mm, Diameter:42.5mm, Lug-to-lug:46.0mm
Crystal: Curved Hardlex
Lumibrite: Yes
Clasp: One-push three-fold clasp
Water Resistance: 10 bar
Magnetic Resistance: Yes
Weight: 165.0g
LIMITED EDITION on the case back
Serial number engraved on the case back
See-through case back
See-through & Screw case back
Unidirectional rotating bezel
This model has both English and Japanese(Kanji) day wheels. (switching by a crown)
English: MON, TUE, WED, THU, FRI, SAT, SUN
Japanese: 月、火、水、木、金、土、日
€388.92
Is er weer eentje zeer geslaagd zijn er slechts 550 van…
Toch onderweg!
Deze SSC951 Asia limited Speedtimer (1000 stuks).
Ben benieuwd naar de live bevindingen!
The base model is the “SRPJ45/SRPJ47,” which pays homage to the “Seiko Time Sonnar” released in the 1970s as the Seiko 5 Sports.
SEIKO X BEAMS 5 SPORTS is an all-black item that uses the SKX series model that is only available overseas. The special translucent dial allows you to see the mechanism of the movement.
Prijs $599.00 USD, ex import. Géén ref.nr.
Doet me heel erg denken aan de mijne. Beter gezegd, dat is dezelfde.
Dit is gewoon de Seiko svbr003 zonder die cartooneske onzin en daardoor dik €100,- goedkoper. ![]()
Het begint in mijn ogen bij Seiko steeds meer op een “special edition” circus te lijken. Ik heb steeds meer moeite om ze als merk tegenwoordig nog serieus nemen. ![]()
Venezianico vibes inderdaad.
Wauw prachtig ![]()
Bij mij ook. Qua prijsstelling lijken ze ook de weg kwijt bij sommige modellen.
En sowieso spreekt weinig van het moderne seiko mij nog aan. Het overdreven positioneren binnen het merk waarbij ze kanjers van horloges opzettelijk onvolkomen lijken te maken… Om je een segment hoger te laten kopen… Erg jammer
als je dit draadje niet volgt zul je merken dat er niets veranderd is.
Ik ga het niet tellen, maar ogenschijnlijk is minstens de helft bedoeld voor de Japanse markt. Schijnbaar pakt dat goed uit want het loopt inderdaad aardig door…
Voor eenieder die het wel wil snappen en niet alleen een eigen mening wil ventileren:
En voel je vooral aangesproken als dat nodig is. Dus ook NIET aangesproken als dat niet nodig is, dat scheelt een boel off-topic. ![]()
Zoals anderen hier al meermaals hebben aangegeven: De meeste van deze releases zijn voor de Japanese Domestic Market only, dan verzamelen we er nog wat andere Aziatische gelimiteerde edities bij, en vervolgens maken de reageerders er hier een potje van door te suggereren dat die releases voor hun bedoeld zijn. Dat is niet zo.
Anime, Manga, en Hentai zijn onlosmakelijk met de Japanse cultuur verbonden, maar vinden ook in andere delen van Azië een publiek, waar het in het Westen met name een niche of een subcultuur is. Dat begrijpen veel mensen hier niet, maar dat maakt niet uit, want deze releases zijn niet voor Europa of de VS.
Ook deze discussie is internet-breed al duizend keer gevoerd.
- Als je Seiko prijzen voor inflatie corrigeert zie je soms zelfs een lichte daling ten opzichte van vroeger.
- Je moet MSRP niet verwarren met een straatprijs na 25 jaar grijze import op, zeg, een SKX of zo. Seiko doet nu meer tegen grijze handel en aan scherpere bevoorrading. Dat is op zich prima, maar niet hetzelfde als een prijsverhoging.
- In alle prijssegmenten waar Seiko actief is, dus tussen de 100 en 350.000 Euro, brengen ze horloges uit die zeer competitief zijn ten opzichte van andere A-merken in de markt. Natuurlijk is San Martin goedkoper, maar dat is een beetje de Euroshopper van de horlogewereld.
Dat is altijd subjectief, laten we dat voorop stellen. Maar als je nou ziet dat de Swatch groep van alles tussen een Tissot van 500 Euro en een Longines van 4000 Euro een potje maakt omdat ze te kleine off the shelf uurwerken gebruiken voor al die shlock denk ik dat de Seiko “onvolkomenheden” nog reuze meevallen.
Merk ook op dat het een Japans bedrijf is met een eigen smoel en een eigen filosofie. Als je daar bepaalde ontwerpen niet van accepteert, prima, maar zij gaan niet doen alsof ze Hans uit Glashütte of Jean uit Neuchâtel zijn voor het volgende ontwerp.
Dat is correct. De zetten blijven zich herhalen.
Daar heb ik het niet direct over, qua value en features geef ik liever elders mijn geld uit inmiddels. Al blijft dat een kwestie van smaak, persoonlijke voorkeur en mening.
Dat ben ik ook wel met je eens, uitzonderingen daargelaten.
Euroshopper
een ouwe, maar accuraat? Ik ben altijd benieuwd naar San Martin maar toch is er altijd iets dat me tegenhoudt om €200 stuk te slaan op een niet eigen ontwerp dat gevoelsmatig €0 waarde voor me vertegenwoordigt. (de original designs vind ik tot nu toe helemaal niks aan en het logo helpt daarbij niet).
Dan 10x liever gevoelsmatig iets te veel uitgeven aan een seiko.
2566, topic:490850"]
[/quote]
Ik ook, maar het mag gezegd worden dat ik het jammer vind.
Het zijn niet zozeer de ontwerpen op hoofdlijnen waar ik op afknap, de meeste kan ik juist waarderen. De aanwezigheid van of het ontbreken van sommige elementen vind ik jammer. Zul je bij de meeste horloges hebben en houden
In mijn beleving is dat onderdeel van het ontwerp.
Als we daar een andere definitie van hebben, excuses, wilde je uiteraard geen woorden in de mond leggen.
Zeker, maar neem nou als voorbeeld dit apparaat:
Een ontwerp dat ik op hoofdlijnen leuk vind. Mooie wijzerplaat en kast, mooie diameter en lug to lug. Qua specs ook aantrekkelijk. Prijs is competitief vergeleken met de concurrentie.
Maar…
Ik vlieg er even met gestrekt been/opzettelijk ongenuanceerd in:
-Dikkerdje met ruim 13mm
-lilleke clasp/gat tussen band en clasp.
De 13mm dikte maakt veel leren bandjes naar mijn mening minder geslaagd. Dan is het imo erg jammer dat de stalen band/sluiting juist iets is waar op bespaard wordt.
-datumvenster dat gek afsteekt tegen de wijzerplaat (dit is smaak/ kan ook ontwerpkeuze zijn)
Dus het is niet zo dat ik het ontwerp nou per se afkeur maar dat er net te veel dingen even anders hadden gekund die het geheel meer kloppend hadden gemaakt.
Ik hoop dat wat ik bedoel zo goed overkomt.
Dat vind ik spijkers op laag water zoeken. In werkelijkheid is het een kleine clasp zoals die ook ooit op de SARB033 zat, en die heel erg comfortabel is, met milled vouwende delen, en een mooi formaat. Dat “gat” is een spleetje wat je nooit gaat zien, want ik neem aan dat je niet gefixeerd op de onderkant van je pols gaat zitten kijken.
Daar heb je gelijk in. Die had 11,5mm mogen zijn, max 12, maar dan houdt het op.
Dat is geen “segmentatie” van Seiko, dat is gewoon omdat veel van hun werkpaard-uurwerken gewoon dik zijn.
De 6L uurwerken zoals je die in mijn limited alpinist ziet komen dan in horloges van 3000 Euro en meer aan bod, maar aangezien die architectuur-trekjes delen met de ETA 2892 uurwerken is het ook logisch dat die in een wat hoger segment zitten.
Maar zelfs “instap” Grand Seiko automaten zijn al dik, waardoor je ook GS horloges van 12,8mm dik ziet, dus het heeft iets te maken met hoe Seiko een uurwerk ontwierp. Ik hoor dat Magic lever systemen het uurwerk ook niet dunner maken, bijvoorbeeld.
Als je bij merken als Tissot, Mido, Hamilton en consorten gaat kijken zie je ook veel van deze ontwerp fouten. Gemengde witte verf met gele lume op dezelfde plaat, datums te ver naar binnen, te dikke kasten, te grote kasten…
Ik vermoed dat je in een bepaald prijssegment moet roeien met de riemen die je hebt als je geen handopwinders wilt gaan maken.
Dus ben ik het wel met je eens dat sommige dingen niet optimaal zijn, maar ze zijn in goed gezelschap, en ik denk dat het geen luie cash grab is.
