I have a seiko 6m13/0010 quartz perpetual calendar and the strap is no longer functional and the glass is scratched, I contacted many places including seiko and they no longer have spare parts. Anyone has spare parts or any suggestions where can I fix my watch?
You could try:
I know he has quite some seiko material in stock.
            If it is only the strap and glass, that should be an easy fix for any watchmaker. The strap cen be replaced by any generic strap in the right width. The glass is a bit more difficult, because it is probably glued. To do this, the glass must be removed and another glass must be mounted with the correct adhesive.
A little info: The 6M13-0010 is also known as Age of Discovery.
            Hey if you are still active here and looking I know several places to source original glass. Not sure about the original strap, that might be impossible.
