Jur, jij hebt het over de skelett uitvoering, maar de A is de gesloten uitvoering.
De link heb ik niet meer, want intussen is de veiling afgelopen, maar ik kreeg een mail retour dat degene die het hoogste bod had niet heeft gereageerd, en ik had dus de één na hoogste bieding
Groeten,
John
Hier staan de specs van de Oversize
Pilot Oversized Automatic
XL Pilot Timekeeper (date indication)
Case
diameter 47.5mm - thickness 15mm
316L stainless steel, satin-finish (matt), plane bezel ring, screw-in exposition back (skeleton), large double protected pilot crown (Swiss cross logo)
shock resistant, antimagnetic, water resistant to 3 ATM (tested for DIN 8308, DIN 8310, DIN 8309)
Movement
High quality Swiss Made mechanical/automatic winding with quick-set date. ETA 2836 - 25 jewels, Swiss lever escapement, Incabloc shock absorber, Glucydur balance, Nivarox 1 flat spiral, Antimagnetic, 28´800 vibrations per hour, Nivaflex spring, ball bearing central rotor with heavy metal weight, power reserve to -47h, Etachron fine adjustment, tight tolerance of adjustment
(also with Cal. 2824 or 2846)
- ETA Manufacture Horlogère Suisse Since 1793
Glass
hardened mineral crystal (curved)
Dial
matt-pilot black with luminous Arabic numerals (a1)
Superluminova advanced lllumination hands and numbers
Band
black padded genuine leather strap, engraved stainless steel buckle, strap width 22mm
Options
- different leather straps available - sapphire crystal
- stainless steel bracelets: 85M3, 85M5, 85M7
- 8554DD-a1 with day and date indication (at 3h)
- 8554DD-Rf2 with Retro dial and day-date indication
