CHRONOMASTER SPORT 160 th ANNIVERSARY EDITION
Reference: 49.3102.3600/51.M3100
Key points: Exclusive blue ceramic edition for the 160th Anniversary of the Brand.
Automatic El Primero column-wheel chronograph able to measure and display 1/10th of a second.
Power reserve of 60 hours. Date indication at 4:30.
Stop-second mechanism.
Movement: El Primero 3600 automatic
Frequency: 36,000 VpH (5 Hz)
Power reserve: 60 hours
Functions: 1/10th of a second chronograph functions. Hours and minutes in the center.
Small seconds at 9 o’clock.
Central chronograph hand that makes one turn in 10 seconds,
60-minute counter at 6 o’clock, 60-second counter at 3 o’clock.
Date indication at 4:30 o’clock
Finishes: Special “160th Anniversary” oscillating weight with satined finishings
Price: 21’900 CHF / 23’700 Euros / 22’700 USD
Material: Blue ceramic
Water resistance: 10 ATM
Case: 41mm / Thickness: 13.6 mm / Lug to lug: 47 mm
Dial: Blue-tones lacquered with three different-coloured counters
Hour markers: Rhodium-plated, faceted and coated with SuperLuminova SLN C1
Hands: Rhodium-plated, faceted and coated with SuperLuminova SLN C1
Bracelet & Buckle: Comes with 2 straps: Blue ceramic bracelet with ceramic folding clasp and blue rubber
strap with steel folding clasp.
PILOT BIG DATE FLYBACK 160 th ANNIVERSARY EDITION
Reference: 49.4002.3652/51.I009
Automatic El Primero column-wheel chronograph with flyback function.
Patented Big Date at 6 o’clock.
Instantaneous Big Date jump in 0.007 sec (0.02 for discs jump & stabilization).
Interchangeable strap system.
Movement: El Primero 3652 automatic
Functions: Hours and minutes in the center. Small seconds at 9 o’clock
Instantaneous Big Date at 6 o’clock. Flyback Chronograph. 30-minute counter at 3 o’clock.
Finishes: Special “160th Anniversary” oscillating weight with satined finishings.
Price: 15’400 CHF / 16’500 Euros / 15’900 USD
Material: Blue microblasted ceramic.
Case: 41mm / Thickness: 14.25 mm / Lug to lug: 52 mm
Dial: Blue dial with horizontal grooves.
Hour markers: Applied arabic numerals in SuperLuminova SLN C1.
Hands: Blue & white with SLN C1.
Bracelet & Buckle: Comes with 2 straps: Blue cordura effect rubber strap and a white cordura effect strap.
Steel triple folding clasp.
DEFY SKYLINE CHRONOGRAPH 160 th ANNIVERSARY EDITION
Reference: 49.9502.3600/51.I001
Date indication. Silicon escape-wheel and lever. Screwed-in crown.
Full Interchangeable strap system. Stop-second mechanism.
Central chronograph hand that makes one turn in 10 seconds, 60-minute counter at 6 o’clock,
60-second counter at 3 o’clock. Date indication at 4:30 o’clock.
Price: 22’900 CHF / 24’800 Euros / 23’800 USD
Material: Blue Ceramic
Case: 42mm / Thickness: 12.7 mm / Lug to lug: 47.4 mm
Dial: Blue-toned sunray starry sky pattern
Bracelet & Buckle: Comes with 2 straps: Blue ceramic bracelet with a double folding clasp and blue rubber
G.F.J.
Reference: 40.1865.0135/51.C200
Key points: Rebirth of the Legendary calibre 135. Chronometer Certified. Breguet Hairspring.
Stop-second mechanism. Exclusive Edition for the 160th Anniversary of the Brand: Platinum case,
lapis lazuli dial and special “bricks” guilloche finishing on the movement.
Movement: calibre 135 manual
Frequency: 18,000 VpH (2.5 Hz)
Power reserve: 72 hours
Functions: Hours and minutes in the centre. Small seconds at 6 o’clock.
Finishes: Exclusive 160th Bricks guilloché
Price: 48’900 CHF / 52’900 Euros / 49’900 USD
Material: Platinum 950
Water resistance: 5 ATM
Case: 39.15mm / Thickness: 10.5 mm / Lug to lug: 45.75 mm
Dial: Blue bricks guilloché on the outer ring, lapis lazuli in the center and mother-of-pearl
small second counter
Hour markers: 18-ct white gold applied indices
Hands: 18-ct white gold faceted
Bracelet & Buckle: Comes with 3 straps: Dark blue alligator leather strap with platinum pin buckle
- black calfskin leather and blue “Saffiano” calfskin leather. Optional for purchase: Platinum
bracelet with double folding clasp
Dusss.
bah lelijk man ![]()
So I heard you guys like blue… right?
Al die blauwe ceramic dingen vind ik een beetje te uitbundig…zo’n cal 135 is dan wel weer tof, vooral vanwege het uurwerk maar ook daar ben ik geen klant in die prijsklasse…
Vriendelijke herinnering: geen horloges ontwerpen zaterdagnacht om 05.00 uur.
Ik ben blij dat het cal 135 weer vast in de line-up komt, hopelijk ook in betaalbare versies. Het blauw is wat veel voor mij maar het is zeker feestelijk !
Gaat het de Elite handwinders helemaal vervangen ?
Betwijfel ik ten zeerste, heel ander afwerkingsniveau dan de Elite.
Deze Cover Girl is dan ook van de buitencategorie ![]()
Blauw is een mooie kleur, dat wel, maar moet alles echt blauw?
Mbt de GFJ, ik zou hem misschien irl moeten zien maar de buitenkant bevat niets wat ook maar enigszins refereert aan de 135 en vind ik eerlijk gezegd een weinig samenhangend allegaartje van ontwerpkeuzes.
Blauw is de huiskleur van Zenith. Bovendien, als je met ceramische materialen werkt, welke kleur zou je dan kiezen om dat te accentueren? Zwart voegt weinig toe, groen, rood of wit zijn net zo goed uitgesproken keuzes dus blauw is nog niet zo gek vind ik. Het is erg opvallend dat ze nu 4 modellen in een fel blauwe kleur uitbrengen maar het zijn dan ook 160-jarig jubileum modellen.
Wat de GFJ betreft, met de ontwikkeling daarvan zijn ze toch 3 jaar bezig geweest. De materiaalkeuzes (platinum, wit goud, lapis lazuli,…) plus het sublieme caliber drukken natuurlijk ook hun stempel op de prijs. Zenith blijft een erg exclusief merk waarbij een serie van 160 stuks mogelijk is. Dit soort actie zou ondenkbaar zijn bij andere gerenommeerde merken zoals bvb. Rolex of Omega, die moeten het echt hebben van grote aantallen.
