Wat vinden we er van? Ik vind hem in ieder geval erg geslaagd!
http://www.twcowatches.com/air-controller.html
The Air Controller, a pilot specifically designed to meet with the demanding aviation environment. The TWCO Air Controller, a tribute to and inspired by the legendary Fairchild Republic A-10 Thunderbolt II forward air controller and its heroic pilots.
The specific design features for the Air Controller:
Bi-directional bezel with both count up and count down function.
Can take both high (depth!) and low (height!) pressure.
Anti-magnetic, ISO 764 annex A 60,000 A/m.
Click here for an explanation.
&DLC coated bezel and the typical pilot look.
Each Air Controller will be supplied with:
Full solid SS bracelet type AC with extension clasp.
Extra/spare pair of SS pushpins.
Screwdrivers for adjusting the bracelet. Click here for instruction.
Supplied in the professional Explorer case.
Movement:
Miyota 9015.
28.800 Beats per hour (4HZ).
24 Jewels.
Power reserve over 42 hours.
Automatic winding.
Specifications:
316L Surgical Grade Stainless Steel.
Sapphire crystal with double
anti-reflective (AR) coating
on the inside.
Bead blasted finish.
Hands & dial indexes with Super-LumiNova®
Screw down crown with quintuple Viton® protection seals. Click here for an explanation.
Double Viton® protection sealed caseback. Click here for an explanation.
20 ATM pressure resistant (water depth 200 meters).
0,2 ATM (absolute) low pressure tested, height approx. 12,000 meters (not correct but sometimes referred to as -0,8 ATM).
Double lug holes. Click here for an explanation.
Measurements:
Case Diameter 43 mm
Bezel Diameter 44 mm
Thickness 14 mm
Lug to Lug 51 mm
Between lugs 22 mm
Functions:
Date display @ 6 H.
Hours, minutes and central second with balance stop (hacking).
Bi-directional 120 click bezel with luminous triangle on the bezel insert (0/60minutes).
Count up and count down bezel functionality.
The 15, 30 and 45 minutes in the bezel are marked in Orange.
Inner ring with 13.00 – 24.00 hour markers.
